Data Modelling: Enable versioning for CKLs and its artifacts
Data Modelling is now a
central service of the zenon Software Platform. It offers a central
repository for all types of structured data both of the zenon Software Platform
as well as custom data models. The data is available via a GraphQL Interface.
zenon Data Modelling is
based on a relational model, similar to an Entity Relationship model. Modular
data models are defined in Construction Kit Libraries.
Management of the data models:
- Support of tenants
- Import and removal of models
- Validation of models
- Administration of versions
Operative
use of data models:
- Comprehensive GraphQL
Interface, which
enables the adjustment and querying of data and the querying of metadata.
- GraphQL
Editor with
autocomplete and integrated scheme documentation
- Online scheme update when
changing the data model
- Validation of GraphQL mutations to scheme
breaches
Note: zenon Data Modelling is still in development. Over time, there
will be more and more data and functionality available.
Item ID: 238730
Version: 12.00 Build: 153415
Data Storage: Enable the management of data in a Web UI
Summary Data Storage enables you to evacuate data centrally via IIoT Services and make it available for other applications. Description Data Storage can now be managed centrally in Service Configuration Studio. The service for Data Storage in Service ...
FAQ: How can I backup the Service Engine data, the data created during Service Engine?
The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
VERSION - Adjustment to project versioning
Summary Project versioning enhanced. Description If a project is restored and versioning is activated, the detail number of the project version (version minor - number) is increased automatically. Item ID: 254465 Version: 12.00 Build: 153415
