Curl & Get Requests to WVS Ops Manager Port will trigger zenRT which never close
The WVS Ops Manager created persistent WVS sessions when curl or Invoke‑WebRequest probes were used on its endpoints.
Those requests did not trigger the instance shutdown timer, causing sessions to remain open and licenses to be reserved.
The issue has been addressed, and the behavior is now as expected.
  • By default, sessions created this way will remain present for 60 seconds. If this timeout should be decreased, add the "InitialConnectionShutdownTimeout" to the [WVS] section in the zenon6.ini to define a custom timespan.
Item ID: 320951
Version: 16.00 Build: 663171
