"Export CEL" function cuts off the Limit Value Text (by using CSV Export)
In some cases the "Export CEL" function will cut off the Limit Value Text (by using CSV Export) by projects converted from older versions. To fix this effect you need to create a new "Export CEL" function in actual version.
    • Dublicated entries after CSV export from CEL
      Description In zenon 8.20, exporting the CEL to a CSV file via the function “Export CEL” leads to duplicate entries. Cause: With zenon version 10, the export of keywords for AML and CEL was implemented. This functionality was also made available for ...
    • AML and CEL continuous export write an empty text for dynamic limit texts that do not use other variables
      Description In a zenon project "Long dynamic limit texts" are disabled for AML or CEL. An entry for reaction matrix or a variable limit value uses dynamic content but does not refer to other variables. For example: " $The value is ;%v". The entry has ...
    • AccessDNP3_SG: enhanced support for CSV import / CSV export
      Description [Feature]: The AccessDNP3_SG Process Gateway CSV export/import function did not support double bit binary inputs. The functional gap has been addressed and the handling of double bit binary inputs is now supported in CSV export/import ...
    • FAQ: How to troubleshoot and resolve High CEL Log volume
      Diagnosis: Identify the offending variables To address high Chronological Event List (CEL) log volume, first identify which variables are generating excessive events. Open the CEL screen in the zenon Service Engine (Runtime) (or in File Inspector). ...
