If continuous SQL export or external storage in a SQL database
is configured in the Engineering Studio for AML and/or CEL, no tables can be
created if the SQL Server version is lower than 2019. Clicking on the "Create
table" button in the respective configuration dialog leads to an
error. The Diagnosis Viewer displays the error code [155] and the
message: "'OPTIMIZE_FOR_SEQUENTIAL_KEY' is not a recognized CREATE
TABLE option".
Cause: In current zenon versions the CREATE TABLE command contained the option "OPTIMIZE_FOR_SEQUENTIAL_KEY = OFF". This is not recognized by SQL Server less than 2019. The table cannot then be created.
This error has been fixed. The respective option has been removed from the "Create table" command. The creation of tables works again for Microsoft SQL Server 2008 and higher.
