Creating or restoring a project backup on zenon 7.11 may fail and lead editor to close suddenly under specific circumstances.
When a project contains invalid variable limit definitions, e.g. a Boolean variable with the same maximum/minimum values, is not possible to create a backup or restore it in zenon 7.11 causing the editor to close unexpectedly with an unhandled exception.
An issue has been resolved where variables with invalid limit definitions are reset to datatype default limit configuration during project backup creation and restoring procedures. Projects can now be backed up and restored successfully in zenon 7.11 editor.
Issue Number: 31753
Fixed on Date: 9.4.2014
Versions: 7.11 0 BUILD 11882
"The docfile has been corrupted." while restoring a backup from zenon 5.50
While you restore a backup from zenon 5.50 in a higher version as 7.20 (7.60 / (8.x) you get in the editor an error text: "The docfile has been corrupted." or, if you setup the editor in German: "Die Dokumentendatei wurde beschädigt" Till version ...
Restoring a project backup in the editor may fail under specific circumstances.
Summary If it is used certain Cyrillic characters in a driver identification, the respective driver configuration file name in the project backup is corrupted, containing invalid characters, preventing the project backup to be restored later in the ...
Checklist: Workspace/Project cannot be created, loaded or backed up
