Creating Analyzer Reports by using the zenon function 'Analyzer: Create Report' does not work
With an Italian operating system it is not possible to successfully execute the zenon function 'create report'. Instead a nessage will be displayed saying 'The parameter of the selected report could not be updated due to the following error: The default timestamp value at index 0 for the report parameter at index 0 could not be converted.'
An issue has been addressed where the time format provided by the italian operating system could not be converted to the time format required by the reports.
Issue Number: 34259
Fixed on Date: 18.5.2015
Versions: zenon Analyzer 2.20 0 BUILD 97 | zenon Analyzer 3.30 0 BUILD 65735
    • Machine Event Counters Report not working any more in zenon 12
      Description In Report Engine version 12, the reports "Machine Event Counters", "Over Revolutions on Load Shedding" and "Active Power on Load Shedding" no longer work after they have been updated from a previous version. The error states that the ...
    • FAQ: What is the difference between the Report Viewer and the zenon Reporting Studio?
      A detailed description of the differences can be found in the attached PDF documents (English and German). The description is based on zenon Supervisor 7.50 and zenon Analyzer 3.00.
