Crash of the Service Engine after using login/logout/switch colors function if html screen opened (Chromium)
In a screen of HTML type, an action is
performed in the Service Engine. For example, a button is clicked. If this
action is performed using a browser with Chromium Engine, then the Service
Engine is terminated unexpectedly. This behavior has been changed. Actions with
a Chromium browser in the HTML type screen no longer cause a crash.
- Update your zenon Software Platform to the
latest build of zenon 10 or higher.
Item ID: 257028
Version: 11.00 Build: 109317
Version: 10.00 Build: 111092
FAQ: Can I translate or change the system texts in the zenon Service Engine?
Yes, it is possible. All system texts in the Service Engine are keywords for the language change functionality, like user defined texts in projects that start with a "@" character. Using the function "Language switch" and the keywords with ...
FAQ: Which IE version is used by the HTML screen? Which Plugins can be executed?
FAQ: When I change something in the Recipegroup Manager via the programming interface in Service Engine, these changes are not updated in the screen. Why is that?
To understand this, you have to know that each time you access the RGM (Recipegroup Manager), you are working with a copy of the RGM data. So every screen that is opened in the Service Engine, has it's own copy of the RGM data. Also each instance ...
FAQ: When I start my zenon project on a Service Engine client, my AUTOSTART script is not executed. What is the problem?
A "script" in zenon is not a snippet of code as you may think in the traditional sense, but rather a configured collection of zenon functions, executed in order. A common use of a zenon script is to load several screens at project startup, for ...
