Crash happens when deleting more than one graphic file in a SOT
If several files such as graphics, help files,
multimedia files etc. are deleted simultaneously in a Smart Office
Template (SOT), the EngineeringStudio is closed unexpectedly. Deleting a single file is
possible without any problems.
This behavior has been modified. Several files can now
be deleted at the same time.
higher.
Item ID: 241994
Version: 10.00 Build: 85877
Summary Now user is able to delete multiple files from graphics, help, mutlimedia.. etc. of File Manager. Crash is resolved now. Description Now user is able to delete multiple files from graphics, help, mutlimedia.. etc. of File Manager. Crash is ...
FAQ: How to import external vector graphic files in zenon?
Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
SOT : crash when creating a new SOT
Description The creation of a new SOT via the Equipment Group led to an unexpected closure after a switch between projects. The issue has been addressed and the behavior is now as expected. To benefit from this fix: Update your zenon Software ...
Deleting of an Referenced Smart Object Template causes Zenon to Crash
SOT: Export of selected screen as XML leads the Engineering Studio to crash
Description If in a Smart Object Template (SOT) a screen is exported as XML, this leads to a crash of the Engineering Studio. This error has been fixed. Screens can be exported as XML in a SOT again. To benefit from this fix: Update your zenon ...
