Copy and paste of values in the value column of the recipe table for recipe values is not always accepted after saving
Under circmstances the changes to recipe values made in the recipe table of the Recipe Group Manager screen in the runtime, using either the default list or a format file of the report generator are not accepted when saving the recipe if the values for string variables or numerical variables were inserted by copy & paste.
An issue has been addressed in the Recipegroup Manager in the runtime where modifications to the value of the recipe variable were not always correctly detected when the value was modified using copy and paste. Now the change is detected correctly and the recipe is saved with the pasted values, provided the values are within the min/max range.
Issue Number: 32485
Fixed on Date: 11.9.2014
Versions: 7.11 0 BUILD 14431
