Control Recipe import with (and without) unit placeholder doesn’t work
In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed.
In Batch Control, a control
recipe with or without a unit placeholder is validated and exported without
errors. If this recipe is to be imported from the export file, the import is
canceled. The Diagnosis Viewer log shows that it could not be imported because
it is not recognized as a valid instance of the master recipe.
This error has been
fixed. The import of valid control recipes works as expected.
To benefit from this
fix:
- Update your zenon Software Platform to the latest build of zenon 11
or higher.
Item ID: 280914
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 231258
Control Recipe import with unit placeholder doesn’t work
Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with a unit placeholder is validated and exported without errors. ...
Setpoint input for Keyboard screen doesn’t work in Batch Control
Description In Batch Control, the setpoint input in a screen of type keyboard does not work as expected. When entering a value via a button that is linked to the function "Setpoint input for keyboard screen", the input is not executed correctly. The ...
Cel print with Switch language in Sub Project from Integration Project doesn’t work.
Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
