Context menu with Display Ext Trend action, doesn't apply the Style group to the Ext Trend screen when using Smart Client
When
using the action type Diplay Extended Trend
in a network project with a Smart Client, the Smart Client was not properly
applying the Syle group linked in the Syle group
chart property of the Extended Trend.
The issue
has been addressed and the behavior is now as expected.
To
benefit from this fix:
- Update
your zenon Software Platform to the latest build of zenon 15 or higher.
Item ID: 309535
Version: 15.00 Build: 539298
FAQ: What are Installation and Security considerations of the zenon Smart Server and Smart Client?
Checklist: Smart Client cannot establish a reliable communication
Time estimate: 60 minutes Please go through all the items in the following checklist. If necessary, confirm any information you cannot verify with the IT department before contacting your local COPA-DATA representative. Checklist usage: #. [Quick ...
Checklist: Smart Client does not work
Context Menu - show Extended trend on More monitor system
Summary Context menu "Show Extended Trend" was always opening trend screen on first monitor. Description Context menu "Show Extended Trend" was always opening trend screen on first monitor. Issue Number: 179320 Fixed on Date: 27.3.2019 Versions: 8.00 ...
