When in an Addin the attributes [Addin] and [AddinName] had assigned names that contained a dot and this Addin was linked to a Execute Project Wizard Extension function, a compiler warning appeared.
The issue has been addressed and dots can be used in the attribut names without warnings.
Item ID: 298774
Version: 14.00 Build: 393950
