Compatible runtime files ignore the transparency of buttons inside symbols from a global project.
Symbols from the global project ignore the transparency configured in buttons if the runtime files are created for any other zenon runtime version.
The issue has been resolved and the correct project and version branches are used now.
Workaround:
Export the symbol library from the global project into the project library gives a set of symbols which can be compiled for older zenon versions.
The Set of Screens can be modified after an XML-Export. (delete (g)).
if (g) is not unique as a prefix for symbols from a global project within a screen it might create new issues
Issue Number: 38753
Fixed on Date: 19.12.2017
Versions: 7.60 0 BUILD 40751
