Comparison Tool: Report does not show correctly Japanese characters
If the report of the Comparison Tool is to be viewed in Japanese, incorrect characters are displayed. In the output window of the tool, the characters are still displayed correctly.
This behavior has been modified. The Comparison Tool report can now also process Japanese characters correctly.
Item ID: 264236
Version: 12.00 Build: 220199
Version: 11.00 Build: 219314
Version: 10.00 Build: 176923
    • FAQ: What is the difference between the zenon Report Generator and the zenon Report Viewer?
    • Comparison Tool: Reports not shown in Comparison Tool
      Description In the Comparison Tool, the report with the result is not displayed in the preview. Instead, a dialog for saving the report is offered. Solution: Acrobat Reader must be installed on the system in order to display and save the report. ...
    • Platform Setup 11: Comparison Tool starts with "Unhandled UI Exception" popup error
      Description When starting the Comparison Tool from the Startup Tool, an "Unhandled UI Exception" is displayed. The Comparison Tool cannot be started. This error has been fixed. To benefit from this fix: Update your zenon Software Platform to the ...
