In earlier times it was like that, that if the option "compare with 2nd time range" was activated that not the whole dialog was displayed at RT but only the few neccessary tabs.
With 8.0 this was changed so that the user can decide if the whole dialog including these tabs is shown or only the tabs for comparing 2 time ranges. For this new case where the whole dialog is shown the mechanism for writing the configured data back into the data structure was not updated. Therefore the data of the second lot filter tab was not written.
In the versions 8.0, 8.10 and 8.20 there was an issue according to the time axis when using comparison with 2nd time range. If you for example used the same lot for both time ranges you were able to discover that the 2 time axis were not displayed the same way and the curves were not lying over each other. When you moved the cursor to the very left or the very right side you also were able to discover that the start or the end time did not really fit to the time filter setting.
This is fixed now.
This is fixed now.
