In command window the name of current action can be displayed in the field "active action/command". When you press the button "Cancel" the text in this field stays. The command window should reset the field "active action/command" when action is canceled. After cancel the field should be empty as before setting the command.
The control element with the name of active command is now cleared when the command is canceled.
Fixed on 29.06.2012; available from 7.00 SP0 Build 2;
