In the command window the button for alternative value is active only for one direction. Using command window it is not possible to set variable in alternative value same as current process value. It is possible only using context menu - where actions for both directions are active.
Now the alternative value in each direction can be activated independent the current value of the response variable.
Fixed on 29.06.2012; available from 7.00 SP0 Build 2;
