Command "Copy" does not work in the output window
After building a zenon Logic project, the information from the output window should be copied. The "Copy" command is available in the context menu and is selected. When pasting into another document, no content is available. The "Paste" command cannot be selected.
This error has been fixed. Content from the output window can be copied again via the context menu and pasted into other documents.
Item ID: 282902
Version: 14.00 Build: 257014
