Color palette description is not displayed correctly under Windows XP
In the editor, the color palette description is not displayed correctly – e.g. too big font, text 45° rotated.
 An issue was addressed in the control used for the color palette. Now, the text is displayed as expected. This issue may also affect the Scheduler module.
 Fixed on 15.05.2012, available from 7.00 SP0 Build 1
Issue Number: 26783
Fixed on Date: 15.5.2012
Versions: 7.00 0 BUILD 1
- Related Articles
- Set colors of color palette to zenon elements via API.- Colors in zenon are a 3-byte code of RGB values. The value #EB29D6 corresponds to a strong pink tone. If these colors are linked directly to a zenon object exactly this value is entered in the dynamic property of the element, screen, textcolor, ...
- The report viewer screen is not refreshed when the color palette is switched in the runtime- Summary When the color palette is switched in the runtime, the report viewer screen is not updated DescriptionWhen the color palette is switched in the runtime, the report viewer screen is not updated Solution An issue has been addressed in the ...
- Searching in the Detail View of the System Information Collector (SIC) does not work on Windows XP- Summary When using the System Information Collector (SIC) on a Windows XP machine and using the search functionality via the key combination Ctrl+F in the detail view (right side), a message box with the text "command is not supported" is displayed. ...
- Dynamic text color from a variable does not work in certain cases when variable limit uses palette colors- Summary When a numerical value and dynamic text element use text color from a variable limit which itself uses a color palette for limit color definition, the color is not set correctly. However when the color is set static, the colors are taken from ...
- When using Windows XP, the editor closes unexpectedly when creating a Send Message function- Summary When using Windows XP, the editor closes unexpectedly when creating a Send Message function Description When using Windows XP, the editor closes unexpectedly when creating a Send Message function Solution An issue was addressed in the ...
