In WVS, a warning is written to the LOG file when a switch or a button configured as a switch is clicked. The warning says: "Element with id [number] did not process command of type primary_pointer_down_command". However, there is no misconfiguration. The warning is not necessary. The same behavior also occurs with the Combined Element.
The configuration check has been changed. There is no warning for correct configuration anymore.
