For the export:
- Engineering content is linked to an equipment model.
- In the equipment model, in the new property Model Type the Substation configuration value is selected.
- The screen elements Line and Pipeline can be used for CIM-compliant configuration with the property Function type as Bus bar or Line.
- If the Model Type in the equipment model is configured properly (Substation), the new property Type is available in the equipment groups subordinate to the equipment model.
This property can be used to configure further parameters of the CGMS standard (geographical area, geographical subregion and substation).
Based on these configurations, the standard-compliant file is generated by running a wizard.
