Checklist: VBA code compilation error
Time estimate:   15 minutes
  1. Error still occurs after reinstalled Microsoft Visual Basic for Applications.
  2. Microsoft Office or other application supporting VBA was installed before.
    1. Older versions of Microsoft Office can create problems regarding compatibility, i.e. Small Business Version for Office 2007 + VBA 6.3.
    2. zenon was running during installation.
  3. Check if the registration of the zenrt32.tlb/zenone32.tlb (both are identical, does not make a difference) is correct for win32 and for win64 in Windows Registry.
  4. -> HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{6F9DE1F1-A404-11CF-95D0-0020D58000EC}\1.0\0\win32
    String value: C:\Program Files (x86)\COPA-DATA\[ZENON_VERSION]\zenone32.tlb
    -> HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{6F9DE1F1-A404-11CF-95D0-0020D58000EC}\1.0\0\win64
    String value: C:\Program Files\COPA-DATA\[ZENON_VERSION]\zenrt32.tlb
    ->HKEY_CLASSES_ROOT\TypeLib\{6F9DE1F1-A404-11CF-95D0-0020D58000EC}\1.0\0\win32
    ->HKEY_CLASSES_ROOT\TypeLib\{6F9DE1F1-A404-11CF-95D0-0020D58000EC}\1.0\0\win64
  5. There are no references required by the code missing. References can be checked in VBA Editor in Tools > References.
  6. zenWorkspace.vba is write not protected. Renamed zenWorkspace.vba so that a new empty file was created.
  7. There are no errors in the code (checked line by line).
  8. Searched in Knowledge Base if a previous issue has been addressed.
