Time estimate: 10 minutes
For the purpose of this step-by-step/checklist guide, logging server and clients are connected via TCP/IP using the following constellation:
Remote logging constellation used as example
- The communication between logging server and clients should be possible. Ping commands must be successful in both directions.
- Make sure there is no firewall or other network traffic restrictions that can block the connection.
- In zenon configuration file (zenon6.ini) of the logging clients,
- Section [NETZ] with the property LOG=1 is present. If not enter it.
- Section [LOGGING_SYSTEM] is present. If not create it.
- In this section enter the following line: LOG_CONFIG=DEVICE=TCP/IP;HOST=REMOTEHOST;PORT=50780;TIMEOUT=10;
In earlier zenon 6.51 or older versions this section was called [SYS_REMOTE].
