Checklist: Process closes unexpectedly (***Reproducible***)
Time estimate: 30 minutes
Terminology:
Service Engine folder = RT folder + Data folder (*).
      RT folder = Service Engine files created by Engineering Studio.
      Data folder (computer name) = Files created by Service Engine during operation (alarms, events, archives, etc.).
(*) Data folder is not necessarily a subfolder of Service Engine folder. Its location can be amended in the project properties.
  2. Process ran and was closed correctly before.
  3. There are not other applications closing unexpectedly.
  4. Searched and followed error instructions in LOGs related with the process-executable closing unexpectedly.
  5. All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
    Service Engine writes log messages in regard zenrt32.exe stability in case of errors or warnings.
    You can find these entries in Diagnosis Viewer by filtering the column Function name = 'CZenonrtApp::MonitoringThread'.
    Some of the most relevant performance entries are:
    - Memory: “Total available memory fell below warning/error level to [xxx]%”
    - CPU: Total CPU-Load exceeded warning/error level to [xxx]%”
    - Service Engine not responding for XXX ms: "100ms Timer has not cycled for [xxx]ms”
    - Handles: "(%) “Handles exceeded error level to [xxx]”.
    In case Service Engine closes unexpectedly, zenon Drivers write in the logs "RPC error!" as they can no longer communicate with zenrt32.exe.
  6. It is possible to establish a:
    1. Periodicity or the exact time when the process closes.
    2. Sequence of actions and/or the functions executed prior to the problem.
  7. Process is responsive before closing unexpectedly.
  8. It is not possible to prevent the process from closing by changing its configuration or avoiding the execution of specific user or other actions/functions.
  9. Searched in Knowledge Base if a previous issue has been addressed.
  10. Cyber security software logs do not report actions to prevent the execution of the process. Cyber-security software is disabled.
  11. Process also closes unexpectedly when zenon API is disabled.
  12. zenon API can be switched off by editing the respective sections in zenon configuration file (zenon6.ini) located in %CD_SYSTEM% folder:
    [VBA]
    [VSTA]
    [ADDINS]
    EIN=0
    ON=0
    ON=0
  13. (Service Engine) Process also closes when the project RT folder has been recreated.
    1. Closed Service Engine.
    2. Renamed (backup) the original RT folder.
    3. Re-created (and remote transported) all Service Engine files.
    4. Restarted Service Engine.
  14. (Service Engine) Process also closes when the project Data folder has been recreated.
    2. Renamed (backup) the original Data folder.
    3. Restarted Service Engine.
  15. [SIC-Full] Collected process crash full dump file in case the component closes unexpectedly and produces an unhandled exception.
  16. Crash full dumps can be generated by adding a [DEBUG] section in zenon6.ini:
    [DEBUG]
    MINIDUMPTYPE=10
    Future full dumps will be saved in the ‘%programdata%\COPA-DATA\zenonXXX’ folder.
If the problem persists after completing this checklist and followed corrective actions, please contact your local COPA-DATA Representative providing a SIC-Full Report from the target computer(s) and the result of this checklist – please include any additional information or comments related with the points addressed you find relevant.
