Checklist: Problems of displaying graphics in Service Engine
Time estimate:  15 minutes
  2. Process ran and was closed correctly before.
  3. No changes were introduced before in Service Engine or Engineering Studio prior to the problem occur.
  4. Searched and followed error instructions in LOGs related with the Service Engine.
  5. All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
  6. The problem remains after rebuilding completely Service Engine files and restart of Service Engine.
  7. The problem occurs also when using other graphics format (e.g. .png instead of .gif).
  8. Operating System and GPU driver are updated.
  9. Disabling graphics hardware acceleration in Engineering Studio does not resolve the issue.
  10. In project properties > Graphical design > Graphics quality select the option 'DirectX Software' or 'Windows Basis' and recompile Service Engine Files. Restart Service Engine.
  11. The problem does not occur in other device.
  12. [Task Manager > Details] GDI objects and handles of Service Engine process (zenrt32.exe) are stable.
  13. Searched in Knowledge Base if a previous issue has been addressed.
