All zenon components write in the background messages to joint log files, which are stored in the folder '%programdata%\COPA-DATA\LOG'.
These files can be read and configured with the Diagnosis Viewer.
You can modify the logging level of a component by clicking 'Client Configuration' in the 'Settings' menu and then selectin the respective process name.
Attention: Set the logging parameters wisely as the time frame of the LOGs decrease when you increase the detail of the written logs.
