Checklist: ActiveX control element
Time estimate: 30 minutes
- All ActiveX elements are installed and registered on the target computer.
- zenon user has sufficient access rights to read and write values/data in ActiveX element.
- Searched and followed error instructions in LOGs related with Service Engine (zenrt32.exe) and Logic Service.
All zenon components write in the background messages to joint log file(s) saved in '%programdata%\COPA-DATA\LOG' folder.
- ActiveX control was developed to be embedded in zenon screens.
zenon has no influence on ActiveX elements, which are not embedded in zenon screens.
- ActiveX references in the programming interfaces are released and deleted properly when a zenon screen containing the ActiveX element is closed.
If not, then there is a danger of a crash or instability of Service Engine.
- ActiveX control supports reload function.
When accessing objects in ActiveX control and the project is reloaded, the references of zenon objects become invalid. This has to be handled in the code of the ActiveX control, as this can lead to instability of zenon components, such as Engineering Studio and Service Engine.
- The ActiveX control works properly when embedded in other application.
- The ActiveX control was compiled to the target platform and operating system (PC or CE) with the correct SDK.
- When registering an ActiveX control on a CE device the registry is saved permanently.
It has to be saved permanently. Every change in CE needs a permanent saving of the registry (i.e. registry of fonts, changing of IP address, changing of client name).
- The ActiveX on a CE device uses the same Class ID as configured on a PC.
- All necessary ActiveX control files are available in the target device (configuration files, additional DLL files, etc.).
- Searched in Knowledge Base if a previous issue has been addressed.
