Changing to a tag value are not saved when the linked variable has a unit and the value is changed in the properties window dialog view.
Changing the value of a numeric command tag that uses a unit (e.g. "kg"), is not saved when the value is changed in the dialog view of the properties window in the editor. Changing the value in the tag list detail view or in the list view of the properties window correctly saves the changes.
Correctly restore modify flag with units.
Issue Number: 29519
Fixed on Date: 3.5.2013
Versions: 7.10 0 BUILD 6571
