Changing any symbol and creating changed runtimefiles is causing all screens with symbols to be compiled even if they don't contain the changed symbol
Screens are compiled each time symbol libray is modified regardless if a symbol used has been touched
Issue Number: 247211
Fixed on Date: 6.12.2021
Versions: 8.10 0 BUILD 92658 | 8.20 0 BUILD 92659 | 10 0 BUILD 92805
Summary In the Engineering Studio, changing a single symbol, not used in any screen, leads to the creation of Service Engine files for all screens containing symbols. This bug has been fixed. Description If changes are made to a symbol in the ...
The XML export of screens may not contain the objects linked to symbols by substitution.
Summary The XML export of screens does not include the variables or functions that are linked to symbols by substitution. DescriptionThe XML export of screens does not include the variables or functions that are linked to symbols by substitution. ...
When creating runtime files for older versions, the Recipegroup Manager data is always compiled in the editor even without any changes
Summary When the setting for creating runtime files for an older version is not set to default in the editor, compiling runtime files will always create runtime files for the Recipegroup Manager, when the option to compile files in RT changeable data ...
Close Screen function closes all screens with the same name even from other projects
Summary The function "Close screen" has been changed in its mode of operation. It now closes only the selected screen, even if there are other screens with the same name. Description When the "Close screen" function is executed, not only the desired ...
