Changing Alarms/Events via ServiceGrid API fails if the alarm/event is no longer available in binary files
The read-back-single-item-mechanism was repaired for external storage of AML and CEL. Setting comments on alarms and events, setting alarm causes and acknowleding alarms works now as expected when only external storage is active (except for the effect shown in the linked related bug).
Enable local binary files.
Issue Number: 241691
Fixed on Date: 0.0.0
Versions: 10 0 BUILD 85877
    • After reloading the runtime on a Windows CE device, alarms and events dissappear from the list.
      Summary After compiling all runtime files, transferring the runtime files and reloading the runtime on a Windows CE device, all current alarms and events are no longer displayed in the list DescriptionAfter compiling all runtime files, transferring ...
    • FAQ: How to import external vector graphic files in zenon?
      Import of vector graphics (DXF and PLT files) is not available for the 64-bit Engineering Studio, so that this can only be done in 32-Bit Engineering Studio. To start 32-Bit Engineering Studio, in the zenon Startup Tool right-click on the respective ...
    • AccessOPCUA: AlarmClass / AlarmGroup no longer mapped for zenon alarms and events
      Description In the project the OPC UA Client is configured as subscriber of the Eventnotifier for AML and CEL. In case of alarms the OPC UA receives the events correctly. However, alarm groups and alarm classes are set to 0. This behavior has been ...
