Changes made to exported properties of a symbol from the global symbol library at a symbol in the local project library are not saved
When a symbol from the global symbol library that uses exported properties for some of its elements is used in a symbol of the local project library, changes to the exported properties are lost after restart of the editor.
An issue was addressed in the editor where exported properties from symbols in the global symbol library are not correctly taken over at instances of this symbol in e.g. a symbol of the project library, when the global symbol library was loaded. Now the changes to exported properties are also available after restart of the editor.
Issue Number: 28914
Fixed on Date: 20.2.2013
Versions: 7.00 0 BUILD 7
