Cel print with Switch language in Sub Project from Integration Project doesn’t work.
Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified.
In a project, the CEL is configured for integration project and subproject. Both projects have a language file. Switching the language works correctly for the projects view in the Service Engine.  But translating in the subproject for printing the CEL does not work correctly.
The translation of the keywords for the printout is only done correctly if all keywords of the subproject are also included in the integration project. If a keyword is included only in the subproject, it will not be translated for printing.
This behavior has been modified. When printing the CEL, all keywords from all projects are translated correctly.
Item ID: 265030
Version: 11.00 Build: 157700
Version: 10.00 Build: 153228
    • Checklist: Printer does not print in the format as expected
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. No .frm file is used to specify ...
    • Variable identification in the Variable Diagnosis screen cannot be translated in Subproject from Integration project
      Summary In the Service Engine, not all variables are translated as configured in the Variable Diagnosis screen. This has been fixed. Description In the Service Engine, with Multi Project Administration, the identification for variables from the ...
    • FAQ: Can I translate or change the system texts in the zenon Service Engine?
      Yes, it is possible. All system texts in the Service Engine are keywords for the language change functionality, like user defined texts in projects that start with a "@" character. Using the function "Language switch" and the keywords with ...
