The filter with a batch identifier for the CEL is applied to the master recipe instead of the control recipe.
Cause:
The control recipe contained an underscore ('_') in the recipe name. This resulted in incorrect filtering.
Solution:
This behavior has been corrected. The CEL is now correctly filtered on the batch identifier even if the control recipe name contains an underscore.
