CEL category: CEL entries XML import of linked categories is not in correct order
In the zenon Categorization exported entries are not always imported correctly. This has been fixed.
In zenon Categorization, CEL entries that are manually linked to categories
are saved in the order in which they were added. After exporting and
re-importing CEL entries, some categories are incorrectly linked. They have to
be reassigned manually.
This error has been fixed. When importing, the
linkings are preserved as configured. The order of CEL entries corresponds to
the order in the XML file.
higher.
Item ID: 268415
Version: 12.00 Build: 180966
FAQ: I would like to create XML Import files manually outside from zenon. Is there a schema definition to validate such XML files?
For the zenon XML Formats there are actually no style definitions available or documented. We recommend to use an exported file (e.g. from the Engineering Studio) as a basis for the manipulation. That's the best way to ensure a proper format of the ...
Visibility lost after Importing Screen XML file
Description During XML import of screens, already existing elements sometimes lose their visibility settings. Linked variables for controlling visibility are not applied. These settings need to be reconfigured. This behavior has been modified. ...
After XML Export and Import the Filter Parameters not correct
Summary If the filter "Linked screens" is used in a screen switch function for a screen of type Faceplate and a screen of a screen container is linked then this is not properly stored with XML expor. This issue has been fixed. Description During XML ...
