Cached credentials don't work when a domain set in project settings
Cached credentials for Active Directory login do not work with zenon Service Engine if a domain has been set in the project settings. This has been fixed.
The project properties "Active Directory domain" and "User group for Active Directory login with caches credentials" have been configured correctly in zenon EngineeringStudio for logging to Service Engine in via Active Directory.
As soon as the computer is connected to the Active Directory domain controller, logon to Windows and the Service Engine with AD users and associated user groups is successful. If the Active Directory domain controller is no longer connected to the PC, it is possible to log in to Windows with cached credentials, but not to log in to the zenon Service Engine. The message "Invalid user name" is displayed here.
This error has been fixed. Logging on to the Service Engine using cached credentials works with the domain defined in the project properties.
  • Update your zenon Software Platform to the latest build of zenon 8.20 or higher.
Item ID: 275067
Version: 14.00 Build: 239777
Version: 12.00 Build: 232473
Version: 11.00 Build: 231258
Version: 10.00 Build: 232665
Version: 8.20 Build: 250795
    • Login with cached domain credentials in the runtime using Active Directory users is not available
      Summary When the option to use Active Directory users is enabled in the project, a login is only successful when one of the domain controllers can be reached. When the domain controller is offline, a login with domain credentials is not possible. ...
    • Cel print with Switch language in Sub Project from Integration Project doesn’t work.
      Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
    • Checklist: Workspace/Project cannot be created, loaded or backed up
