When clicking on the checkbox to enable or disable the History of Changes for a project in Editor, you get a message box that changing the state will close the Workbench (if open) of zenon Logic. You can select Yes or No. In both cases, the property will correctly change its state. However, the level of detail will only change along when Yes is selected.
Answer 'No' should mean no change in the property at all.
Now, when the user selects "no", the workbench is not closed and the change of the property is not taken over.
Issue Number: 30541
Fixed on Date: 9.12.2015
Versions: 7.60 0 BUILD 36068
