By temporary login and value changes via keyboard screen the CEL stores entry with user SYSTEM instead the logged-in.
If you change the value via the keyboard screen (property: Write Set Value -> Use screen Keyboard and Choose a screen) and use the temporary login, then as user it is SYSTEM in the CEL displayed and not the logged-in user. CEL entries about value changes made via standard dialog or element are not affected.
Issue addressed and solved like expected.
Issue Number: 34162
Fixed on Date: 10.11.2015
Versions: 7.60 0 BUILD 36068
