Button enters the "pressed state" even if needed rights are missing
Needed rights are checked before the button enters the pressed state now.
Issue Number: 125429
Fixed on Date: 10.1.2018
Versions: 7.60 0 BUILD 44685 | 8.00 0 BUILD 46644
Button as switch shows invalid state before a variable value is available
Summary A button element configured as a switch displays an invalid state in the Service Engine before a variable value is available. This behavior has been modified. Description When a screen is opened in the Service Engine, a button element that is ...
In the formula edit dialog, the replace button might be activated, even though no tag is selected
Summary When the paste button is used to fill a formula into the formula edit dialog for a condition in the Batch control module, the replace (tag) button is activated, even though no tag is selected. Clicking the button won't do anything. ...
Unexpected State detected for License dongles
The license central indicates an unexpected state for a certain dongle if the state of the dongle - given in a license request or license confirmation file - does not match that one which is calculated by the license central. A reason for this can be ...
Error: The license transfer cannot be confirmed
Errorcode 0x18080010 The following error message is displayed in the license web depot if the license transaction is intercepted by a second license transaction and therefore the license confirmation file cannot be processed. Error The license ...
