BeckhoffNG structured Variables cannot be imported from TwinCat 3.1 Build 4018 Project file (TPY)
When .tpy-File is generated in TwinCat 3.1 Build 4018 and has structured Variables:
While reading the .tpy-File during an import of variables the BeckhoffNG-Driver stops working (stack overflow).
Using TwinCat 3.1 Build 4016 with same TwinCat-Project:
Works as intended.
Works as intended.
The XML tags for arrays have changed in the tpy file. Now this changes are considered.
Issue Number: 34061
Fixed on Date: 20.4.2015
Versions: 7.10 0 BUILD 19354 | 7.50 0 BUILD 25796
