Beckhoff NG driver imports arrays wrong
When importing variables from its TPY file, the Beckhoff TwinCat NG driver imports arrays incorrectly. The cause is that the selection is based on the ID (decoration), but if IDs are present more than once, the data type cannot be assigned correctly.
This behavior has been changed. The selection of the variables to be imported and the sorting of the arrays now takes place via the name of the type. Arrays are imported correctly again by the Beckhoff TwinCat NG driver.
  • Update your zenon Software Platform to the latest build of zenon 7.60 or higher.
Item ID: 183004
Version: 8.10 Build: 59911
Version: 8.00 Build: 59775
Version: 7.60 Build: 59794
