Batch, RT-Function, File-Storage-Folders: Runtime-Function 'Batch Import Recipe' is not working after converting project from 8.20 to 10
- The XML-paths will be built correctly
- The default paths will be built correctly
Issue Number: 244202
Fixed on Date: 12.10.2021
Versions: 10 0 BUILD 91105
When configuring a C compiler for a driver simulation project the driver stops working when starting the runtime
Summary When configuring a C compiler for a driver simulation project the driver stops working when starting the runtime When starting the runtime the driver tries to register itself and seems then to stop immediately. When configuring compiler ...
BATCH CONTROL - Function authorization for export of recipes
Summary Batch Control now has a new function authorization for exporting recipes. Description The export of recipes in Batch Control also allows access to the device's file system. This can now be restricted. For this purpose, the setting "Batch ...
FAQ: Can I change the storage type for RGM in an existing Project? What do I need to consider? What are the benefits?
Summary Solution Yes, you can change the storage type in the Recipe Groups Manager module from Access DB to binary storage, or vice versa, also in existing projects. The first two steps are only required when your runtime has priority over RGM recipe ...
Runtime shuts down unexpectedly with a project that runs a Batch Control recipe and provides data for external processes.
Summary It may happen in rare cases that the runtime shuts down unexpectedly when a Batch Control recipe is being executed and the Runtime is accessed by an external program, e.g. the OPCUA process gateway DescriptionIt may happen in rare cases that ...
