Batch Control: Switch phase doesnt work properly for similar units
In Batch Control, switching between phases of different units is not done correctly. This has been fixed.
If control strategy is used in Batch Control,
the parameters of the control strategy are retained when switching from one
phase of a unit to a phase of another unit with "Switch phase" button. Phase 2 from Unit 2 thus displays
the parameters of Phase 1 from Unit 1.
This error has been fixed. The parameter list is
cleared when switching. When selecting a control strategy, the correct
parameters are displayed.
higher.
Item ID: 261936
Version: 11.00 Build: 157700
Batch Control: Switch Phase option doesn't update control strategy list control which can lead to write wrong parameters
Summary In Batch Control, switching between phases in the same unit is not done correctly. This has been fixed. Description When switching from one phase to another phase of the same unit in Batch Control with "Switch phase", the control strategy is ...
Batch control: On inserting a phase the service engine crashes
Description In Batch Control, the Service Engine crashes when a new phase is inserted into a master recipe in the editor. This error has been fixed. Phase insertion works as expected again. To benefit from this fix: Update your zenon Software ...
Setpoint input for Keyboard screen doesn’t work in Batch Control
Description In Batch Control, the setpoint input in a screen of type keyboard does not work as expected. When entering a value via a button that is linked to the function "Setpoint input for keyboard screen", the input is not executed correctly. The ...
