Batch Control: Service Engine crashes when a "%" character is used in the name for Matrix or PFC recipe
In Batch Control, the character "%" is prohibited for recipe names. However, the input was not prevented. If the recipe name contained the character "%", the Service Engine crashed when the recipe was saved.
This behavior has been modified. The Service Engine no longer crashes when "%" is used. Saving a recipe now is only possible if the name is entered correctly.
Item ID: 269700
Version: 12.00 Build: 180966
Version: 11.00 Build: 176384
    • Batch control: On inserting a phase the service engine crashes
      Description In Batch Control, the Service Engine crashes when a new phase is inserted into a master recipe in the editor. This error has been fixed. Phase insertion works as expected again. To benefit from this fix: Update your zenon Software ...
    • FAQ: How can I backup the Service Engine data, the data created during Service Engine?
      The path of the Service Engine folder can be amended in the project properties and it is set into zenon6.ini (VBF30=) when the start project is set in Engineering Studio or in zenon Startup Tool. In the Service Engine folder, there is the subfolder ...
