When using zenon Editor 7.20 and later you may choose between the modules Batch Control and Command Sequencer. In older versions only Batch Control is available. Still, if you select the module Command Sequencer and then compile Runtime files for an older version, the Batch Control module can´t be used.
The described issue has been resolved. When creating Runtime files for older versions, the option for the preferred module will be ignored, so that Batch Control is available
Issue Number: 32108
Fixed on Date: 11.2.2016
Versions: 7.60 0 BUILD 36068
