BATCH CONTROL - Function authorization for export of recipes
Batch Control now has a new function authorization for exporting recipes.
The export of recipes in Batch Control also allows access to the device's file system. This can now be restricted.
For this purpose, the setting "Batch Control: export recipe/operation" has been added to the "Function authorizations". If there is an "Authorization level" assigned to it, exports can only be executed by a user who possess the corresponding "Authorization level".
This applies to
  • Master recipes
  • Control recipes
  • Operations
This functionality was developed for zenon Software Platform version 15 and is available from version 10.
To benefit from this feature:
Batch Control: export recipe/operation function authorization
The Batch Control: Export recipe/operation entry has been added in the User Administration project property underthe function authorizations Service Engine. This includes authorization for the following functions:
  • Export Batch recipes
  • Screen type specific action of the Batch Control screen
    • Export control recipes
    • Export master recipes
    • Export operations
Item ID: 280897
Version: 14.00 Build: 257014
Version: 12.00 Build: 272744
Version: 11.00 Build: 272743
Version: 10.00 Build: 258580
    • FAQ: Recipes in RGM cannot be edited / RGM incompatibility of recipes between different builds in version 8.20.
      There was found an incompatibility in the Recipe Group Manager (RGM) in zenon 8.20 Build 70282, 79336, 80198, 80611 and 81129. An issue was detected which causes the RGM recipes of the affected builds to be no longer compatible with recipes stored ...
    • Control Recipe import with unit placeholder doesn’t work
      Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with a unit placeholder is validated and exported without errors. ...
    • Control Recipe import with (and without) unit placeholder doesn’t work
      Summary In Batch Control, the import of a control recipe that was previously validated without errors fails. This error has been fixed. Description In Batch Control, a control recipe with or without a unit placeholder is validated and exported ...
