"#" is not an allowed character in zenon variablenames. It shouldn't appear as a suggestion for a property separator within the BacnetNG driverconfiguration.
Side effect:
If a hash is used, these variables cant be used in a extendet trend screen. No curves are dsplayed.
Side effect:
1) Removed the item '#' from the combo box with the predefined seperators
2) Added a check if # or @ is selected and "Use identification for addressing" is disabled. If the check Fails, a warning message box is displayed and the dialog is closed. The user may still use @ or # as seperator
3) During import all # and @ in variable names are replaced by _
Issue Number: 31361
Fixed on Date: 26.2.2014
Versions: 7.20 0 BUILD 17768
