B&R PVI Software provided on the zenon Setup Image cannot be installed on Windows 10
The B&R PVI Software which is included in the zenon ISO Setup cannot be installed on Windows 10.
Renewed the B&R PVI Software which can now be installed on Windows 10
Issue Number: 35462
Fixed on Date: 5.11.2015
Versions: 7.50 0 BUILD 25796 | 7.60 0 BUILD 36068
    • Checklist: Software-dongle is broken
      Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick hints] ...
    • FAQ: Are COPA-DATA downloads affected by Trojan Havex RAT? How can I verify if the downloaded setup is the original non-modified version of this setup? Does zenon use OPC Server?
      Malware producers of the Trojan Havex RAT have recently focussed on Industrial Control Systems. Through security holes, installer files for software used in industrial control systems have been modified on different vendors websites without them ...
    • Vulnerable zlib library in zenon setup
      Description zenon Softwareplatform 11 and 12 contained outdated zlib components that were found to be vulnerable. These have been replaced with latest zlib version 1.3.3. To benefit from this fix: Update your zenon Software Platform to the latest ...
