Azure Process Gateway - Removing a large quantity of variables from the "Exported into MS Azure" column can take a long time or lead to unexpected behaviour.
In the Azure Process Gateway, removing a large quantity of variables (~1000) from the column "Exported into MS Azure" can take a long time or lead to unexpected behaviour.
The process of removing variables from the "Export into MS Azure" column has been optimised to reduce the time taken and to improve overall stability.
Issue Number: 35643
Fixed on Date: 25.11.2015
Versions: 7.60 0 BUILD 36068
