Automatic calculation of relative values by the Metering Point Administration does not work.
Even though metering points are correctly configured as automatic metering points with automatic relative value calculation, the calculation won't work. The value of the variable remains unchanged.
In the windows task bar it can be seen that the zenon logic program "MeteringPoint" is not running because of the errors
Missing function resp. function block 'ARCHIVTRIGGER'.
Missing function resp. function block 'VACO'.
An issue has been addressed where the automatically created zenon Logic project "Metering Point" could not be started due to an internal error. After the fix, the project will start as normal.
Issue Number: 34321
Fixed on Date: 5.5.2015
Versions: 7.20 0 BUILD 19742
