At the CEL display properties the graphics file and circle symbol were not correctly changed via language switch function.
Under specific circumstances the CEL column settings Alarm/event class symbol and Alarm/event group symbol Display property it was not possible to change the language using the language switch function.
An issue was addressed in the language switch function. Now, after using the language switch function, the column settings tab of the CEL filter screen show the display context menu options translated.
Issue Number: 29998
Fixed on Date: 12.9.2013
Versions: 7.11 0 BUILD 10238
Checklist: Problems of displaying graphics in Service Engine
Time estimate: 15 minutes Please go through all the points in the following checklist. If necessary, confirm with IT Department any information you cannot verify before contacting your local COPA-DATA Representative. Checklist usage: #. [Quick ...
FAQ: How to troubleshoot and resolve High CEL Log volume
Diagnosis: Identify the offending variables To address high Chronological Event List (CEL) log volume, first identify which variables are generating excessive events. Open the CEL screen in the zenon Service Engine (Runtime) (or in File Inspector). ...
graphics for switch elements are not displayed or display an incorrect value in the runtime
Summary Sporadically the graphics for switch elements may not display correctly or display the incorrect value DescriptionSporadically the graphics for switch elements may not display correctly or display the incorrect value Solution An issue has ...
Cel print with Switch language in Sub Project from Integration Project doesn’t work.
Summary Printing the CEL from a subproject after a language switch does not work correctly. In another language translated Keywords are not included in the Print. This behavior has been modified. Description In a project, the CEL is configured for ...
